2000 Dodge Van
2000 DODGE VAN
10,700 MILES • 6 CYL • 2WD • AUTOMATIC
BIGBASS
runs rough only for mintue which has a popping from the air cleaniing housing and burst of air, step on gas noise gets louder no power hesitation put in drive without stepping on gas it shakes driveing it started popping lost power wont go let of gas it goes away but wont go until coast awhile then everything is good noise sounds like it from front right allso just had tuneup with plugs wires cap rotor coil
Feb 25, 2009 at 3:19 AM
  • 110,240 POSTS
Hi:
If you are getting a popping from the intake, chances are there is a burnt intake valve. Perform a compression test to see if there is a cylender that has low compression.
Also, has the check engine light come on?
Mar 14, 2009 at 7:10 AM
