1999 Dodge Van vibraton
BARTANTON
  • 1999 DODGE VAN
  • 6 CYL
  • 180,000 MILES
My van vibrates around 50mph and above. I can turn the engine off at those speeds (with it in nuetral) and it goes away. Is this my torche Converter?
Thursday, June 18th, 2009 AT 4:25 PM
CARADIODOC
  • 33,873 POSTS
Good observation. The torque converter spins at the same speed as the engine, so you don't have to kill the engine, just put it in neutral and let it idle. Also, the vibration will come back if you increase rpm while standing still. I had a broken hub on my torque converter that caused a vibration that would come and go every few seconds. That lasted for over three years before it finally broke enough to allow fluid to leak out. Before you dig that far into it, I would suggest you look at the harmonic balancer to see if the hub is loose or cracked, or if the outer ring has shifted on its rubber insulator. A loose outer ring is real common on some Ford truck engines, but it could happen on any engine.
Caradiodoc
Wednesday, June 24th, 2009 AT 5:19 AM
