1999 Dodge Van Delayed shifting into 2nd
1999 DODGE VAN
123,000 MILES • 6 CYL • 2WD • AUTOMATIC
AWILLARD
I'm experiencing a problem when my van engine is cold, for example in the morning after sitting overnight. After backing up and turning hard out of my driveway, the acceleration into second gear is hesitating. It's not jerking, but it seems reluctant to shift into second. As the engine warms up, or if I am accelerating without turning, for example at a stop light, it's not having this problem. Additionally, changes into other gears seem fine. I have had much work done on the van in the past year, including service to the ignition, catalytic converter, air pump, and recently the rear differential. I also have recently installed a new air filter. But am I now seeing the early signs of a transmission problem? Thanks
Sep 17, 2009 at 1:12 AM
CH112063
  • 1,320 POSTS
Throttle pressure could be adjusted to have it shift sooner but since it only happens cold and your transmission fluid is fine leave it. It is not a sign of transmission complete failure, just age.
Sep 24, 2009 at 1:08 PM
