1998 Dodge Van Stalling
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
SAMSDELI
My van will be driving like it should and all the sudden it will stall. When I try to restart it, I have to try to start it two or three times before it will start. Replaced the ignition coil, crank case sensor and it has not helped. Checked plugs, wires and coil everything looks good.
Crank case gear is good, no cracks. Once is a while it will kinda jump right before it stalls.
Any advise of what to try next?
May 15, 2009 at 8:56 AM
  • 75,988 POSTS
Check the fuel pressure and test the ASD and fuel pump relay to include the coolant temperature sensor
May 15, 2009 at 9:59 AM
