1998 Dodge Van OBD reading cylinder 6 misfire
164,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHRIS HAZELWOOD
OBD reads cyl 6 misfire
I have replaced plugs, plug wires
dist cap and rotor
replaced injector
compression check 148-152 all cylinders
replaced coil, all have power
still at idle- very rough
with acceleration runs smooth with mild ping
? only thing I haven't changed was distributer itself
? any suggestions
Nov 24, 2009 at 11:16 AM
  • 31,937 POSTS
HI there,
I think that the ping is the clue to this problem, can you do a live data read and check ignition timing specs, also check for vacuum leaks around this cylinder.
Mark (mhpautos)
Nov 24, 2009 at 11:24 AM
