1998 Dodge Van
1998 DODGE VAN
BRIT_LAD
1998 Dodge Van
I had a flat battery on my 98 dodge ram van (interior light left on over night). I tried jumping it and had no real luck so then I charged it, will start if I press the accelerator down a good way but dies when I lift off, also when it does run with accelerator down it seems to be smokey? Is this somthing to do with the fuel system?
Oct 28, 2008 at 10:36 AM
BMRFIXIT
  • 19,053 POSTS
Is it derivable car you take it for a quick spin around the block
if you can do it as the idle may need to be relearned by the PCM
see when the battery dies the PCM will loose all it memory and have to relearn it
try to take it for a ride if u can
check if u have any code son it
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 1, 2008 at 3:55 PM
