1997 Dodge Van warning lights
250,000 MILES • V8 • 2WD • AUTOMATIC
PHANTOMRF
i disconnected 2 wire connectors under the hood then i properly put them back. they were for the "parking brake" and "abs". the warning lights came on on my dash and now will not go off or reset.
someone said the computer is thinking a "pending problem" may exist and they should reset themselves.
but when??
the check engine light never came on. it is the set of warning lights such as the "gen", "seat belts"
"abs" and parking brake" etc that normally go off in a few seconds after starting the engine but the "abs" and "parking brake" lights are still on
Nov 18, 2008 at 8:35 AM
  • 110,248 POSTS
Hi:
I believe there is a scan tool that is needed to reset this issue. However, try disconnecting the battery for around 10 minutes to see if that will do it.
Let me know what you find.
Dec 2, 2008 at 8:29 AM
