1997 Dodge Van van
NMGOBLIN
Electrical problem
1997 Dodge Van V8 Two Wheel Drive Automatic
I have a van with the following problems: when I turn on the van and start driving it just turns off. I'll turn it on again drive for awhile or a couple of days w/no problem and it'll turn off again.
Jul 7, 2010 at 1:52 PM
  • 110,248 POSTS
Has it ever not restarted for you? Have you checked fuel pump pressure and has the check engine light ever come on?
Jul 7, 2010 at 5:22 PM
NMGOBLIN
no it always starts right after and no i have not check fuel pump preasure how much psi am i lookin for and thank u for ur help and no engine light
Jul 8, 2010 at 2:46 PM
  • 110,248 POSTS
It should be between 44 and 54 PSI. The fact that the check engine light isn't coming on makes me lean toward the fuel system. However, it could be something like a crank sensor. Let me know what you find with the pressure.
Jul 9, 2010 at 1:15 PM
NMGOBLIN
hi joe i checked the presure on fuel pump ok but i did find the light bulb for check engine light came off the dash board and it was on so i put my scanner on it ,i gave me this code p0118 ect sensor voltage too high what should i do? thanks
Jul 10, 2010 at 5:13 AM
  • 110,248 POSTS
Most likely culprit is the ECT (engine coolant temperature) sensor.
Jul 10, 2010 at 5:35 AM
