1997 Dodge Van Blower motor
DANNO69
Heater problem
1997 Dodge Van 6 cyl Two Wheel Drive
My blower motor works intermently, sometimes it will run then shut then start again
Mar 3, 2009 at 1:19 AM
  • 110,248 POSTS
Hi:
It could be a loose wire, bad resister, or a motor going bad. When the motor stops, you need to check to see if the motor is still getting power. If so, it either has a bad ground or the motor is going bad.
Let me know what you find and we'll go from there.
Mar 14, 2009 at 7:04 AM
