1996 Dodge Van coolant in engine oil
168,000 MILES • V8 • 2WD • AUTOMATIC
AIRPORT AUTO AIR
have coolant in the oil; milkshake, pressurised cooling system, can hear it escaping, have 140-145 lbs compression in all 8 cylinders. considering; intake gasket,timing cover told they rot out NOT sure where to begin
Jun 29, 2010 at 9:54 AM
BLACKOP555
  • 10,386 POSTS
perform a compression test to see if its headgasket related or intake manifold gasket related.
Jun 30, 2010 at 5:54 AM
AIRPORT AUTO AIR
I already did that and it is 140-145 all cylinders
Jun 30, 2010 at 9:00 AM
BLACKOP555
  • 10,386 POSTS
you have no moisture anywhere that you can see a visible leak? i would start with intake manifold gasket. less of a bear to replace then the timing cover gasket.
Jul 8, 2010 at 5:25 AM
