1995 Dodge Van will not start
200,000 MILES • 6 CYL • FWD • AUTOMATIC
BCWATSON
Van was getting hot. We would stop and put water in it. Did this for a couple of weeks. Then one morning it stopped running and would not start. Does it have a wngine kill switch on gas or electrical??
Jul 1, 2010 at 8:58 AM
  • 75,988 POSTS
It doesn't have an inertia switch/kill switch-what you need to do is determine if its a fuel or spark problem that's preventing it from starting-Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard i
Jul 1, 2010 at 9:09 AM
