1995 Dodge Van When cold. van wont start.
155,233 MILES • 6 CYL • 2WD • AUTOMATIC
DARRIN0819
I changed out the thermostat cause it was blowing out cold air. after that i went to start it and it turns over but it wont start. i have to hold downt the gas then it will fire then die. i got to keep doing that till it starts and idles on its own. after its started it reves up then it goes down. it keeps doing it every morning. after its warmed up it starts much better. but it still has problems. HELP!!!
Jan 7, 2010 at 1:06 PM
  • 75,988 POSTS
Check the fuel pressure if okay-check and test the idle air control motor,coolant temperature and throttle position sensors-
Jan 7, 2010 at 2:16 PM
