1995 Dodge Van fuel problem
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
CONCOUR
My dodge ram van start to run rough and shuts off when it gets warm. I have to keep my foot on the gas pedal to keep it from shutting off whenever i get to a stop sign or stop light. Is this a problem with the fuel pump? Does this van have a fuel pressure regulator? If so, where would I find it? Could this be a problem with the fuel filter?
Jan 11, 2009 at 5:44 AM
  • 110,248 POSTS
Hi:
The regulator is on the fuel rail. As far as the pump, here is a how to for checking fuel pressure. I would check to see what kind of pressure you are getting.
https://www.2carpros.com/dia/test_fuel_pressure.htm
Let me know what you find.
Mar 14, 2009 at 10:14 AM
