1995 Dodge Van ECM
20,500 MILES • 6 CYL • 2WD • AUTOMATIC
DUZITALL
Have replaced cam and crank sensors and put in a used ECM and van just dies while driving( all other electrical works ) just no fire to coil or distributor. Checked all relays(kill relay ,ignition relay,neutral safty switch. What else can I do? p.s. check engine light never comes on during failure or while driving. only when initial ignition is turned on
Dec 16, 2009 at 11:37 PM
  • 75,988 POSTS
Hi duzitall, Welcome to 2carpros and TY for the donation and selecting us to assist in your auto repair needs. Feel free to ask questions at anytime.
I want you to check for power at the coil dark green and orange wire and also at the injectors harness. If okay check and test the coil, distributor pick-up coil and ignition control module and then report back with some results.
Dec 17, 2009 at 12:32 AM
DUZITALL
if it is i.c.m. wouldn't it not start at all? Why would ignition shut off while running? All ready checked coil power-when won't fire,no power to coil. Is i.c.m. on fire wall by power brake drum(side by side with shut off relay)...if so all ready checked them by swapping plugs. Do I need to rest ECM to my van since it came out of another used van?
Dec 17, 2009 at 12:47 AM
  • 75,988 POSTS
All ready checked coil power-when won't fire,no power to coil. If you're refering this power at the coil as battery voltage-check and test the ASD relay and for battery voltage at the dark green and orange wire at the coil and injector harness then report back with some testing results
ICM when it heats up this is where problem could exist causing your problem
Dec 17, 2009 at 7:18 AM
