1992 Dodge Van no fire to the ignition system
MIKEALBERT
  • 1992 DODGE VAN
  • V8
  • 93,000 MILES
I have a 92 dodge van it turns over but it won't start. I did a power test to find out that I wasn't getting any power tp the coil nor the pick up. What could be the problem?
Tuesday, February 9th, 2010 AT 6:51 AM
CARADIODOC
  • 33,916 POSTS
Sorry for the delay in replying. Did you figure it out yet?
The ignition coil will only have 12 volts for one to two seconds after you turn on the ignition switch. The voltage won't show up again until the engine computer sees engine rotation, (cranking or running). If the voltage is missing during cranking, suspect the crankshaft position sensor or the camshaft position sensor in the distributor.
Caradiodoc
Friday, February 12th, 2010 AT 2:23 AM
