1992 Dodge Van Just Quits running and hard to restart
THEMIXMAN
  • 1992 DODGE VAN
  • 6 CYL
  • 150,000 MILES
Van starts runs for a few mins anywhere from 5 to 30 mins then just stops and is hard to restart,
I can restart it after 10 mins or so, but same problem runs then stops. I have changed the fule pump, but still same problem.
Sunday, January 3rd, 2010 AT 4:01 PM
Do below immediately, to determine if it's a fuel or spark problem:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Sunday, January 3rd, 2010 AT 11:58 PM
