1992 Dodge Van fuel
11,298 MILES • V8 • 2WD • AUTOMATIC
DPETE4
My van will crank and run for a few minutes then shut off, have had fuel pump replaced and it still does the same thing, also replace fuel fiilter with no luck. Whne it shuts down I can mass the fuel reliefe valve and it has no pressure. If you wait a few minutes it will crank again and then sut down after a few minutes.
Oct 11, 2009 at 11:17 PM
  • 75,988 POSTS
Check the fuel pressure with a fuel pressure gauge and make sure its within specifications
Oct 11, 2009 at 11:22 PM
