failed for HC in new jersey
167,539 MILES • V8 • 2WD • AUTOMATIC
LOSTINMYHEAD1
my van failed for HC by 14 points nj requires a HC reading of 100. the vans was 114. i did a tune up, plugs wires, rotor cap, air cleaner and pcv. should i try a new cat..
Apr 28, 2009 at 10:24 AM
This measurement is measuring how much raw fuel or hydrocarbons exist in the exhaust.
So, this could be a converter but before we go there, we need to run through these guides and make sure there are no codes and then review the smog test guide as well since NJ is similar to CA.
https://www.2carpros.com/articles/smog-test-inspection-information
Next, we are going to have to test the converter to find out if it is reducing the hydrocarbons enough. If the engine is running properly and not misfiring, then more than likely the converter has failed.
This guide will help with this:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
I suspect you are correct based on this info, but we need to run through this first and then we can take the next steps.
Thanks
Mar 20, 2022 at 1:38 AM
