1991 Dodge Van hard to brake
100,000 MILES • V8 • 2WD • AUTOMATIC
JHON1991
since i bought the dodge van 1991 always i fix my brakes,front and rear never had a problem on till couple month ago, i did the brake like always but now it is hard to brake, i replace all mechanical part and electronics, i bleed th brake clean the line i have done everything that you can imagine trying to fix this. please need help
Nov 20, 2008 at 12:57 PM
  • 110,248 POSTS
Hi:
Do you mean the brake pedal is hard to push? If so, theck the vacuum hose going to the booster. It may have a leak or the booster itself may be the problem. You'll need to have a vacuum test done on it to see if it holds vacuum.
Dec 2, 2008 at 8:23 AM
JHON1991
[quote:9c36d1ff86="Jacobandnickolas"]Hi:
Joe[/quote:9c36d1ff86]i did all of that, new booster,master cilynder,combination valve, proportioning valve,calipers front and back,disk, drums, abs computer,check for vaccum leak, what could be wrong this is crazy and i am geting crazy too, thanks
Dec 2, 2008 at 12:31 PM
  • 110,248 POSTS
Hi:
Is the brake pedal hard to push?
Dec 2, 2008 at 1:01 PM
JHON1991
[quote:562be5cd7e="Jacobandnickolas"]Hi: yes, nothing behinde,according to the book of the van i did read a part that said before you turn on the engine you press the the pedal three or four time on the press you leave it press then you turn on the engine, if the pedal go down is good but is not happening like the book said, and i check the hose coming from the power booster to motor and the suction in vaccum is it good. thanks
Is the brake pedal hard to push?[/quote:562be5cd7e]
Dec 3, 2008 at 11:30 AM
