1990 Dodge Van Want start
56,000 MILES • V8 • 2WD • AUTOMATIC
GEOBUG
Was running great . Started up without any problems. Move it back in the driveway.Then went to start it again to move it back in the carport & all it would do is crank without starting. Have replaced the plugs, & coil & coil wire. Still won't start. What could be the problem?
Aug 25, 2009 at 2:42 AM
JDL
  • 16,098 POSTS
Hello, did you try any basic testing? Have a helper crank it, while you visually check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. Any codes?
Aug 25, 2009 at 2:52 AM
