Brake Antilock Warning Light On?
90,000 MILES • V8 • 2WD • AUTOMATIC
ROLLSSROYCE
What is the probable cause for this light to come on and how to fix the problem??
Aug 23, 2009 at 10:53 PM
  • 110,251 POSTS
What lights are coming on?
CODES
System faults are identified by a series of flash codes that operate through the anti-lock warning lamp. The CAB will store and display one fault code at a time. Flash codes may be retrieved by temporarily grounding the anti-lock diagnostic connector.
Oct 11, 2009 at 5:45 AM
ROLLSSROYCE
The brake light and anti lock light stay on. This occoured after replacing the EMC to fix a charging problem. Since then, I have replaced the front brake pads and calipers, and turned the rotors. The back brakes have not been touched. Also, the odometer does not work. The speedometer works, but is not accurate. The speed control works but looses speed slowly. I replaced the speed sensor, but that did not fix the problem. Any ideas on how to fix this 1990 Dodge B250
Oct 11, 2009 at 6:23 AM
  • 110,251 POSTS
The self test feature of the control module is activated whenever the ignition switch is turned to ON or RUN position. If a system fault is detected, the control module illuminates the ANTILOCK light and stores the fault code in memory. Fault codes are retained in memory even after turning the ignition switch to OFF position. Please check the images below
Oct 11, 2009 at 1:37 PM
