1988 Dodge Van Any fuel/air adjustment on throttle body system
1988 DODGE VAN
DAVID LAU
1988 Dodge Van V8 Two Wheel Drive Automatic 86k miles
The error message on check engine light shows too rich on fuel after I replaced the 2 fuel injectors. Is it possible to calibrate or adjust the fuel/air ratio so my RAM B-250 able to pass 'the test' only smog testing.
Nov 19, 2008 at 4:01 AM
  • 110,244 POSTS
Hi:
There are no adjustments. Everything is done by sensors. Make sure the O2 sensor is working.
Dec 2, 2008 at 8:26 AM
