Engine Mechanical problem
1977 Dodge Van V8 Two Wheel Drive Automatic
I have an RV with a 1977 Dodge B300 van front end. I've been getting white smoke (steam?) out the exaust along with some coolant blowing out. I'm getting misfires on one side when it idles.
I assume this is a cracked head/block or head gasket gone bad.
Where can I get the torque sequences on the header bolts so I can replace the head gaskets? I've never done one myself as I'm just learning about engine repair, but it seems pretty straight forward and I'm willing to attempt the repair.
It's a v8 with 4 cylinders on each side. I should probably replace both sides, but in a pinch is there a problem with doing just one side now and the other side when I have more time?
May 6, 2010 at 1:49 PM
