1973 Dodge Van
CBVANSICKLE
Brakes problem
1973 Dodge Van V8 Two Wheel Drive Automatic
pedal goes to floor when applied but won't return except manually i've replaced the master cylinder front calipers pads and rear shoes is there any thing else that i'm missing that would cause this
Feb 25, 2009 at 7:28 AM
  • 31,937 POSTS
Hi there,
Make sure that you have bleed the brakes of air completely, make sure that all the brake lines are tight and you have no leaks, check this first and report back and further problems if the pedal is not improved.
mark (mhpautos)
Feb 25, 2009 at 8:29 AM
CBVANSICKLE
have bleed all air out talked to dealer they say they think it is n linkage disconnected powerboost pedal moves fairly easy, they say booster most likely not to go out, but could cause problems if it did, i'm going to replace brake booster next.
Feb 26, 2009 at 12:42 AM
