1996 Dodge 2500 Column Shifter Sticks
DAKOTADAVE
1996 Dodge 2500 auto trans 2wd
Tranny has been acting like it sticks in between gears when I shift from park to drive. After working the gear shift lever it seems to pop back into the proper slot and works fine, it has done this 3-4 times before. Yesterday it did it once again, but after trying to get it to pop back in the column gear shift handle actually broke off from inside the steering column. Any ideas?
The handle is not broken the interior where it connects inside the steering column broke. The real problem is not fixing the shift handle, but diagnosing the problem of why it sticks in between gears, but acts like it is shifting smoothly with the lever. Seems to be an internal trans problem.
Oct 7, 2007 at 11:30 PM
BMRFIXIT
  • 19,053 POSTS
[quote:120763761f="dakotadave"]1996 Dodge 2500 auto trans 2wd
Tranny has been acting like it sticks in between gears when I shift from park to drive. After working the gear shift lever it seems to pop back into the proper slot and works fine, it has done this 3-4 times before. Yesterday it did it once again, but after trying to get it to pop back in the column gear shift handle actually broke off from inside the steering column. Any ideas?[/quote:120763761f]
Did it brake off or came off
Broke off you have to replace it and check the shifter cable
Good luck
Let us know
Oct 7, 2007 at 11:37 PM
Suggested Repair
Replace the broken column shifter connection and inspect the shifter cable for binding or misadjustment.
Conversation Summary
The owner of a 1996 Dodge 2500 said the column shifter sticks between park and drive, then works after the lever is worked. The internal column connection later broke while trying to free it. The expert advised replacing the broken shifter part and checking the shifter cable.
