2007 Dodge Truck Fault code P2000
10,200 MILES • 6 CYL • 4WD • AUTOMATIC
KENNY350
This is a 2500 4X4 6.7L diesel. It has NOx absorber efficiency below threshold Bank 1 code. What is a NOx absorber, where is it, what does it do, can something else bring in this code? Which side is called bank 1?
Jul 2, 2010 at 9:46 AM
RICHZOMBIE
  • 173 POSTS
Remove and replace both Oxygen Sensors with p/n 05149263AA. If your vehicle is still under warranty this may be covered. Also, you can try taking them out and blowing them off then replacing them, sometimes this works.
Jul 2, 2010 at 10:06 AM
KENNY350
So the NOx absorber is the O2 sensors?
Jul 17, 2010 at 10:46 AM
MERLIN2021
  • 17,250 POSTS
I sent you a PDF explaining your options and testing the problem...
Jul 18, 2010 at 12:47 AM
