2006 Dodge Truck
2006 DODGE TRUCK
98,000 MILES • 6 CYL • 4WD • AUTOMATIC
JIM TSCHRITTER
Signal lights stop working some times along with wiper blades. Problem only when steering wheel is in down position.Is it a wiring or control switch problem?
Aug 7, 2010 at 9:09 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I would be removing the steering column trim and inspection the loom for the switch, check for a loose plug or a fault in the wiring where it may be damaged, start here.
Mark (mhpautos)
Aug 7, 2010 at 12:39 PM
