2005 Dodge Truck Won't Start
25,000 MILES • 6 CYL • 2WD • AUTOMATIC
J#
  • 5 POSTS
Diesal, Start's in the morning,but as the day goes on it won't start. Crank's over but won't fire. Startes on either.No codes, 8psi fuel presure between filter and pump. Sometimes starts fine.Help!!
Oct 8, 2008 at 10:41 AM
  • 110,248 POSTS
Hi:
I have to do more research, but 8lbs doesn't sound right to me. I was thinking more like 15. I will try to find it for you, but if you know someone at the local dealership, they may get you a quicker answer.
I'll let you know what I find. Let me know if you find out before I do. Finally, when you checked the fuel pressure, was it during a time the truck wouldn't start?
Oct 8, 2008 at 2:04 PM
J#
  • 5 POSTS
I think I seen 8-10 someplace. It will hold 8-10 during cranking. it will go below 5 during heavy acceleration Run's good after starting
Oct 8, 2008 at 2:19 PM
  • 110,248 POSTS
Hi:
According to google, 10 PSI is normal. Now I have a stupid question for you. You said you checked the pressure between the pump and filter. Does it loose any after the filter? I realize that you most likely already know to check the filter, but since I'm not there, I don't want to assume.
Oct 8, 2008 at 3:50 PM
J#
  • 5 POSTS
I finally got a code P251 Fuel control relay.But I can't find it? it not in the fuse panel like it's suppose to be?
Oct 9, 2008 at 2:29 AM
  • 110,248 POSTS
Hi:
check under the hood in the power distribution center.
Oct 9, 2008 at 3:23 AM
J#
  • 5 POSTS
The book say's it's there but it's not on my truck
Oct 9, 2008 at 4:17 AM
  • 110,248 POSTS
Hi:
I'm sorry, but I'm not there to look. Therefore, I suggest you take it to a mechanic for the location. I wish I could help you better, but the miles between us stops that.
Good Luck,
Oct 9, 2008 at 4:28 AM
J#
  • 5 POSTS
Loose Cross Tube !!!
Oct 14, 2008 at 4:32 PM
