2005 Dodge Truck P/S Pump
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
NANKECONST
Need to replace pump. Are there any tricks to easy replacement? Do I have to do resivior and pump together? Do I need to replace any gaskets that do not come with parts?
Feb 5, 2009 at 4:44 AM
  • 110,246 POSTS
Hi:
There are not tricks. I recommend replacing the pump and resivour at the same time. That way you eliminate a possible leak. Also, if you get the pump / resivour as a unit, there are no gaskets required.
Mar 13, 2009 at 6:41 AM
