2005 Dodge Truck Nock
94,000 MILES • V8 • 4WD • AUTOMATIC
ALVENT
I have a 2005 dodge ram sLT.I drove from ohio to miami and i have what sounds like a knock in the motor.It gets louder when it first starts up and it slows down when the truck shifs gears.What is the problem and what should it cost to fix.
Dec 11, 2008 at 8:24 AM
  • 110,246 POSTS
Hi:
If the sound is coming from the engine and affected by RPM's, it could be a few things. You may have a bad rod bearing, crank bearing... You will need to have it looked at by a mechanic that can hear it. In the interum, make sure the oil if full and clean. If it's one of the things I listed, it may be an expensive fix.
Let me know what you find.
Dec 12, 2008 at 8:55 AM
