2005 Dodge Truck deisel
69,245 MILES • 6 CYL • 4WD • AUTOMATIC
MIKE TERVORT
my truck has oil and exaust coming out its blow by hose it seems to be to much what does it take to fix it
Aug 24, 2008 at 4:09 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation.
The first thing you will have to get done is have a compression test done and a leak down test to check the condition of the rings, your problem is usually a result of over pressurizing the sump this is caused by compression by-passing the rings. If the oil has not been changed or incorrect oil used as a mixture with diesel oil can cause the rings to fail causing this blow by, start with the compression test and a service with a good engine oil flush will not hurt either, start here.
Mark (mhpautos)
Aug 24, 2008 at 3:10 PM
