2004 Dodge Truck fuel problem
2004 DODGE TRUCK
126,394 MILES • 6 CYL • 4WD • AUTOMATIC
CUPPY2
I had water in my fuel tank but I got it out. Changed fuel filter. Truck ran for two weeks after I did these things now the engine cranks but doesn't start. I have fuel to the injectors.
Sep 13, 2009 at 5:35 AM
JDL
  • 16,098 POSTS
Welcome to the forum. Engine cranking, do you have spark at the plugs? Use a gage and check fuel pressure.
With the engine cranking, is there primary voltage to the coil and injectors?
Sep 13, 2009 at 6:01 AM
