2004 Dodge Truck blower motor hvac
89,000 MILES • V8 • 4WD • AUTOMATIC
AGARROAD
blower motor just stopped. worked when I parked the car, the next morning it didn't. I believe it is the blower motor resister. I need to find it and replace it. Can you help ?
Thanks
Jul 20, 2010 at 7:24 AM
SATURNTECH9
  • 30,869 POSTS
What model truck do you have?If it doesn't operate on any speed then i would say it wasn't the resistor.Let me know what model truck you have and i will get you the trouble tree.Resistor's are expensive you don't want to replace one unless it's bad.
Jul 20, 2010 at 7:51 AM
SATURNTECH9
  • 30,869 POSTS
agarroad Says>1500 slt, 4x4, crew cab, 5.7 liter engine. fan was working fine when i parked it. 2 days later went to use truck and no fan at any speed. checked what i think was fuse (40 amp) fuse looked fine, st.
saturntech9 says>I couldn't find a trouble tree for your blower motor inop.So let's do this find your blower motor it's behind the right side of the dash.There should be a dark blue wire and a dark blue and yellow wire going to it.Put your fan speed on high with the key in the run position now see if you have battery voltage to those two wire's if you do and the motor isn't working then you have a loose connection to the motor or a bad motor.Let me know what you find.
Jul 21, 2010 at 6:10 AM
