2004 Dodge Truck 4 X 4
130,000 MILES • V8 • 4WD • AUTOMATIC
SHANE7
The service 4 wd light is on and the 4 x 4 doesn't work. The truck is an AWD. I would like to know what the problem could be.
Apr 4, 2009 at 2:30 AM
CARADIODOC
  • 34,413 POSTS
Your truck is not "All-Wheel-Drive"; that's a minivan thing. Four-wheel-drive implies that when you decide to engage it, at least one front and one rear wheel will propel the truck. The AWD designation is used to prevent people from thinking they can go off-roading with it.
There are hundreds of parts that make up the four-wheel-drive system including the transfer case, front axle, and vacuum-operated shift fork on the axle. Any one of them can prevent the system from working. Someone will have to actually look at it and make some tests to determine the cause of the problem.
caradiodoc
Apr 7, 2009 at 6:10 AM
