Idles rough, and RPM's jump at idle.
2003 DODGE TRUCK
88,000 MILES • V8 • 4WD • AUTOMATIC
SERGEYEMT
The problem I am having, is when the truck is rather in neutral, or I am standing at a red light with my foot on the break, the RPM's jump under 500, then up over a thousand, and they will continue bouncing up and down until I start driving, a few times the rpms fell low enough that the truck actually stalled, although restarted with no problem. It also seems to lose a little power at cruising speeds, requiring me to push on the gas harder to pass a car, and this causes rpm's to jump up fast. I got it tuned up, but the problem still exists. Could it possibly be the Idle Air Control, or the EGR Valve failure.
Thanks
May 25, 2009 at 4:44 AM
BMRFIXIT
  • 19,053 POSTS
Check for a vacuum leak as a 1st step also do a code check you can check and clean IAC too let me know
May 25, 2009 at 10:03 PM
WAIN ZAIN
  • 5 POSTS
Same truck but mines a 2500 hemi. Mines pretty rusty under there. Same issues and getting worse. What was the problem and your solution? My ac seems to have gone really warm during this issue as well. Texas heat... probably just needs charging but i thought it may be worth mentioning or be connected. Thx, Zain
Aug 7, 2019 at 6:45 PM
  • 55,443 POSTS
The AC shouldn't effect the engine running. to me it sounds like the throttle actuator is dirty here is a guide to help fix it
Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response.
Aug 8, 2019 at 3:35 AM
WAIN ZAIN
  • 5 POSTS
Yeah sure. Thanks for the response
Aug 8, 2019 at 12:54 PM
WAIN ZAIN
  • 5 POSTS
I drove it all day today and it didn't act up one time. So strange
Aug 8, 2019 at 12:56 PM
  • 55,443 POSTS
Thanks for the video. We should run the codes also does it have the catalytic converter still on it? Sounds like you have an exhaust system maybe?
Lets do this guide next.
Aug 9, 2019 at 5:36 AM
WAIN ZAIN
  • 5 POSTS
No lights have ever come on. but I took it to O'Reillys anyways thinking that maybe the bulb was out on my check engine light. but I was told no light, no codes, no information.
Aug 9, 2019 at 10:23 PM
  • 55,443 POSTS
Lets start with a tune up and the throttle actuator service that way we can rule them out. also look at each plug to see if one is different coloring that the others which can indicate the cylinder that is giving us problems. Here is a guide to help us:
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
and
https://www.2carpros.com/articles/engine-vibration-at-idle
Aug 10, 2019 at 4:38 AM
BILLN457
i have a 03 dodge ram 2500 5.7 hemi when i start it up the idle jumps up and down try's to stall and it dose stall sometime's and when i put it in to gear it runs rough for a few but come's out of it and run's fine until i shut it off when i start it again it starts allover again
Aug 10, 2019 at 7:16 AM (Merged)
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
BILLN457
i have replaced most of the thing u have said but still dose the same thing
What was the reading on the idle air control valve and throttle position sensor-
BILLN457
how would i get a reading on that stuff
What did you replaced ? you need to troubleshoot all of it -don't waste your money throwing parts to it hoping it will fix it
BILLN457
i have replaced plugs and wires 02 sensor sofar
WAIN ZAIN
  • 5 POSTS
Same truck. Mines pretty rusty under there. Same issues and getting worse. What was the problem and your solution? My ac seems to have gone really warm during this issue as well. Texas heat... probably just needs charging but i thought it may be worth mentioning or be connected. Thx, Zain
