2003 Dodge Truck replacing brake pads
2003 DODGE TRUCK
85,000 MILES • V8 • 2WD • AUTOMATIC
NATE MELENDY
I'm replacing the brake pads on my 2003 pickup, using a large clamp to seat the caliper cylinder on the driverside front worked. With passenger side front caliper, I can't get the cylinders to both go in, one is in and the other is stuck in the extended position. Also the rubber gaskets around the cylinders are cracked and one has some fluid coming out. Please help...
Sep 7, 2009 at 2:02 PM
  • 110,244 POSTS
If the piston is stuck and the caliper is leaking, it needs replaced.
Oct 7, 2009 at 4:18 AM
