2003 Dodge Truck OBDII error code for 2003 Dodge Ram 1500
2003 DODGE TRUCK
100,000 MILES • V8 • 4WD • AUTOMATIC
HASLEPI
My 2003 Dodge Ram 1500 gives the below error could when tested? What needs to be replaced to fix the problem?
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
Dodge Ram 1500 Quad Cab 4X4 - 5.9 v8 Engine
Dec 1, 2008 at 3:06 PM
DOCFIXIT
  • 18,828 POSTS
Check cat for cracks ands discoloration due to heat.
Check for exhaust leaks. If all good then are both O2 OEM one could be slow to respond cvausing code.
Also any oil or antifreeze in exhaust will cause code.
Dec 2, 2008 at 4:58 AM
