2003 Dodge Truck front wheel bearings
2003 DODGE TRUCK
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
STEVEN THOMPSON
are the wheel bearings replaceable if so are they pressed in or loaded normally needle bearing style
Feb 13, 2010 at 10:53 AM
DR LOOT
  • 2,311 POSTS
remove the dust covers, remove the collar key, remove the nut and a bearing should come out, you will have to remove the disk to get to the inside one. No they are pressed on.
Feb 19, 2010 at 2:37 AM
