2003 Dodge Truck Erroneous Light Warning
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROYAL KIRKWOOD
I have checked all my bulbs and fuses inside and outside. I continue to get a visual/audio alert on the dash that says "Lamp Out". I don't have any codes coming up on the vehicle according to the shop I took it to. The only help they could give is the Update that there is an "Erroneous Lamp Alarm" but not what to do about it. The dinging is getting to me. Thanks for any help.
Apr 21, 2009 at 8:05 AM
  • 55,859 POSTS
Hi, it sounds like you may have the wrong bulbs installed or the warning module has gone bad. Sometime it is separate for the BCM and sometimes it is integrated. Make sure you check the middle brake light, and all interior lights also. Please get back to me with the results.
Apr 22, 2009 at 11:59 AM
