Engine Performance problem
2003 Dodge Truck V8 Automatic 85203 miles
My truck runs fine for the first 4or5 miles and when I stop at a stop sign it sometimes stalls but starts right back up. Then it will run fine for a mile or two then lose power and act like it is only running on one or two cylinders. I shut it off then it will start right back up and run fine for several miles!
The check engine light is on and it shows a Trouble Code P1494 Evap Leak Detection Pump Pressure Switch.
Would this cause the truck to act like this? Also where is this switch located?
Thank's
George
Thank's
George
Feb 27, 2010 at 4:50 PM
