2002 Dodge Truck p1762
60,000 MILES • V8 • 4WD • AUTOMATIC
NICK ANDRES
where can i locate that probem, p1762 (governor pressure sensor
Feb 7, 2008 at 10:41 AM
MOPARTECH9423
  • 25 POSTS
Which transmission do you have? If your truck has a 5.9L gas V8, then you have a 46RE. I'm pretty sure that's what you have if you're getting this code. You most likley will have to replace the governer pressure sensor and the temp sensor in the valve body. It the cheapest possibility and the easiest place to start.
Feb 8, 2008 at 2:13 PM
