2002 Dodge Truck lights
123,696 MILES • V8 • 4WD • AUTOMATIC
SOUPIESON
all the lights on my truck will not turn off after turning the engine off. I've turned the light switch to the off position and the auto position and they still will not go off. Now my batteries are going dead. Dodge 1500 SLT Quad cab 4x4 with the 5.9L engine, Any help
Nov 26, 2009 at 12:46 AM
JDL
  • 16,098 POSTS
welcome to the forum, Have the codes checked? The instrument cluster receives signal from headlamp switch. Then the instrument cluster sends a buss signal to the front control module. The front control module sends voltage for the headlamps. Without a code or something to point us in the right direction, I'd have to check the wiring circuits.
Nov 26, 2009 at 3:09 AM
