2002 Dodge Truck left rear BRAKE LIGHT
59,000 MILES • 6 CYL • 2WD • AUTOMATIC
REDHAMMER
i CHECKED THE BULB AND THE RUNNING LIGHT WORKS BUT THE BRAKE LIGHT DOES NOT
Nov 27, 2009 at 1:32 AM
JDL
  • 16,098 POSTS
Welcome to the forum, did you use a testlite to check for voltage at the suspect brake lite, white wire with lite green tracer. The brake signal goes to the instrument cluster, the instrument cluster sends a buss signal to the front control module. The front control module sends voltage to the lamp. If there are any codes, it might point you in the right direction?
Nov 27, 2009 at 1:52 AM
