2002 Dodge Truck fuel system
130,000 MILES • V8 • 2WD • AUTOMATIC
PRHFL
Truck starts and idles o.k., when given gas it sputters and shakes especially going up hill. Could this be a filter or pump problem? Thanks
Jan 5, 2009 at 12:07 AM
JDL
  • 16,098 POSTS
If you think it is a fuel issue, check fuel pressure. One of the gages from a discount store is better than nothing. Some of the stores will let you borrow a gage, you may have to put up a deposit, you will get it back.
How long since a tune-up? plugs--plug wires--filters-- cap and rotor where applicable. These are all maintenance items. If you replace the fuel filter, just make sure there is no pressure on the system before you take any lines loose.
You might check for codes, some of the national brand stores will check codes for free.
Jan 5, 2009 at 5:12 AM
