2002 Dodge Truck
BRAD RIGGLES
  • 2002 DODGE TRUCK
  • V8
  • 4WD
  • 92,500 MILES
Transmission slips when I turn to the left and step on the gas what could be wrong
Tuesday, July 21st, 2009 AT 3:35 PM
DR LOOT
  • 2,311 POSTS
Have you checked the transmission fluid? It only does it when you turned to the left? I think were starting to go in to the Twilight zone the only thing I can think of is that you have a loose connection on the wiring harness on the transmission when you turn left the wiring harness moves and causes of our function, once you get out of the truck and make sure the wiring harness is not flopping around.
Friday, July 31st, 2009 AT 10:52 PM
