HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Truck
Engine
Symptoms
Stall at Idle
2001 Dodge Truck Truck dies sometimes when putting in gear
BLUESTEEL789
MEMBER
2001 DODGE TRUCK
6 CYL
2WD
AUTOMATIC
128,800 MILES
Dodge truck sometimes dies when put in gear / mostly when putting in reverse. What could be the problem.
Tuesday, July 22nd, 2008 AT 2:28 AM
MECHANIC
Test the idle air control motor, throttle position and manifold absolute pressure sensors.
Tuesday, July 22nd, 2008 AT 5:48 AM
BLUESTEEL789
MEMBER
Thanks I will try that
Wednesday, July 23rd, 2008 AT 2:29 AM
Please
login
or
register
to post a reply.
Related Engine Stall At Idle Content
1997 Dodge Truck Stalls When In Reverse
Everytime I Try To Go In Reverse When The Truck Is Cold It Stalls. Once I Put The Truck Back In Park It Starts Right Up With No Problems But...
Asked by
Nitefighter
1 ANSWER
1997
DODGE TRUCK
GUIDE
Engine Stalls After Dead or New Battery
So you installed a new battery and now the engine stalls? You have done nothing wrong because believe it or not this is normal. The engine computer has a learning cycle...
Cold The Motor Wont Idle And Runs Bad?
When Its Cold The Motor Wont Idle And Runs Bad. When Its Warm Out It Idles And Runs Fine Throttle Body No Choke
Asked by
lisa shoemaker
1988
DODGE TRUCK
1977 Dodge Truck Engine Stalls At Low Speed And At...
Engine Performance Problem 1977 Dodge Truck V8 Two Wheel Drive Automatic Unknow Miles My 77 Dodge Truck Has A Rebuilt Engine With About...
Asked by
nsmith7
1 ANSWER
1977
DODGE TRUCK
1979 Dodge Truck
The Engine Idles Fine Until I Shift The Transmission Into Gear. The Engine Dies Unless I Manage To Maintain 1000 Rpm Or More. The...
Asked by
Fred Ranta
1979
DODGE TRUCK
1997 Dodge Truck
Engine Mechanical Problem 1997 Dodge Truck V8 Four Wheel Drive Automatic My 97 Dodge 4wd Truck Idles Iradicly And Dies When I Put It...
Asked by
pfb32
1997
DODGE TRUCK
VIEW MORE
Stalls at Idle
Backfire Repair
Change Oil and Filter Chevrolet 7.4L 454
