134,000
When I push down on the gas peddle to move the truck it will red line the tac unless I let up on the gas peddle. When the truck is in O/D and I press down on the gas peddle hard the transmission shifts down to 1 and will red line until I let off the gas peddle. When the truck is in O/D and 2 geer the transmission does not slip at all. What should I check to fix this problem
Jul 7, 2008 at 4:21 PM
