2001 Dodge Truck Starter turns over but won't crank
83,000 MILES • 6 CYL • 4WD • AUTOMATIC
STEPHEN 8730
When starter is engaged the fuel pump does not operate but when you let off starter the fuel pump will run for about 5 to 10 seconds.
Oct 9, 2008 at 6:57 AM
  • 75,988 POSTS
Check the fuel pressure and injection pulses
Oct 9, 2008 at 8:36 AM
STEPHEN 8730
Checked the pressure going to injector pump and is about 10 psi for about 5 to 10 seconds then shuts off. Pump does not operate or has 0 psi when starter is engaged.
Oct 9, 2008 at 8:59 AM
