2001 Dodge Truck running then dies after 15 minutes
CHEIFCYCLE
Engine Performance problem
2001 Dodge Truck 6 cyl Four Wheel Drive Automatic 68.000 miles
i have a 2001 ram with 5.9 cummings.The primmer pump went out and replaced it and the filter.bleed the pump and the injectors 3/5/6.now the truck runs about 15 minutes and dies and wont restart for a while .i was hopeing the pump wasnt ruined from lack of fuel to cool the pump .i hope i can get some help with this. thanks
Jun 30, 2009 at 3:20 PM
DR LOOT
  • 2,311 POSTS
you may have some electrical problems, there is an ON and OFF solenoid located on the pump and only has one wire going to it, started up when it dies again make sure there's 12V volt going to the solenoid.
Jul 11, 2009 at 6:36 AM
