2001 Dodge Truck over heating after several....
DMSTRUNK
Engine Cooling problem
2001 Dodge Truck V8 Two Wheel Drive Automatic
my truck is over heating I have replaced the water pump,thermostate,radiator cap,clutch fan and used anti freeze recomended in my manual . Still this truck is over heating at a temp close to 280 degrees. Also I don't see leaking water/anti freeze. Can you help me?
melvin
Jul 30, 2010 at 8:55 AM
  • 75,988 POSTS
Radiator okay-try bleeding the cooling system could be air inside-are you actually boiling over if not CTS might be misleading you
Jul 30, 2010 at 10:11 AM
